TheFrailer's avatar
TheFrailer
Jacking up a 5th wheel
It's time for me to do maintenance on our 2003 Trail lite 5th wheel. It has tandem Dexter axles. I'd really like to be able to lift the entire trailer so that I can do all the wheel maintenance at once (and possibly live in it while this is going on... we are full timers).
Can anyone point me in the direction of how such things are done? I'm specifically looking for blocking strategies. How many sets? Where?
I'm figuring the landing legs for one side and a bottle jack to lift the axle's off the ground?
Just starting to research how to go about this. Would like to know how to lift this trailer without damaging it.
Thanks in advance for your input!
  • IMHO this works VERY well! I did all my maintenance on my 18K Mobile suites using the TrailerAide Plus. This was a road side repair along the Coast in CA. No Issue doing one wheel at a time.
  • First get side to side level. Then lower the front landing legs all the way down. Put jack stands behind rear spring hanger. Raise landing gear until wheels are off the ground. Put jack stands under front spring hangers and snug with wood wedge.
  • Jack stands & a 12 ton bottle jack are relatively cheap.
    Start with trailer still on the truck. Crack all wheel lugs loose. Lift one side just fwd of spring hanger. With both wheels off the ground, jack stand just aft of spring hanger. Don't remove wheels yet. You want them there as insurance just in case something slips as you repeat the lift on the other side, same way.
    Getting to this point you will have tipped the trailer fwd placing more weight on the 5th wheel. The landing legs may or may not be powerful enough to lift the front high enough to get the truck out. No problem. Use the jack to lift & extend legs so that there is no weight on the truck at all.
    At this point the truck can be removed without any pull on the trailer at all & the trailer is as solid as a house on the ground. Now the wheels can come off.
