fj12ryder wrote:
All the owners' manuals say that.
If you jack in the middle of the axle you will probably bend the axle since it isn't designed for that. If the builders said that it is okay to jack on the axle, and someone jacked in the middle of the axle and bent the axle, then they would holler that "The builder said it was okay to jack on the axle."
Consequently the builders put in a CYA statement that never to jack under the axle. If you ever tried to raise your trailer high enough to change a tire, you'd understand how ludicrous the idea is that you have to jack under the frame.
With you 100% on this, jacking on the frame solves the idiot from jacking in the middle and bending it out of alignment. Jacking on the frame to raise a wheel off the ground requires at least 6" of travel if not more, and you have put some serious twist in the frame.
If the tube of the axle was so thin that placing a bottle jack under it to jack, then the first big bump you hit would have a wheel pointing sideways.
