blofgren
Nov 23, 2021Explorer
4x4ord wrote:Cummins12V98 wrote:
Auto mode is useless unless you are towing a lighter RV and smaller grades at least with RAM trucks.
I also set my cruise control at a lower speed to maintain the actual speed I want. It varies depending on how steep the grade is. I also on steep grades select the gear that puts me up near the redline for best braking.
I am glad I don't have the ability for the truck to apply my trailer brakes. I like controlling me descent with cruise and proper gear selection for the grade. I never use Auto mode, I have tried but found it useless for my large load.
Could there be something wrong with your truck? The EB on the Cummins should generate 60 lbs of back pressure on a steep grade with a heavy load regardless of whether it is set to auto or full on.
I think his load is 33-36,000 lbs so I don't think there's anything wrong with his truck. ;)
I too only use full exhaust brake mode with my truck.
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 31, 2026
