Rollochrome's avatar
Rollochrome
Jake Braking A 5er Down Long Steep Incline
Just arrived at our vacation destination yesterday.
I had my factory “jake”brake set and the cruise control on when I crested the top of the largest hill going into this part of the country. I’ve never towed a fifth wheel through this kind of environment before and felt like I was looking over the top of a roller coaster when I looked down the several mile long descent
My F350 downshifted all the way into third gear and held me at 55 miles an hour from the top of the mountain to the bottom of each mount I encountered
After I went up and down several mountains like this however it occurred to me that I might be creating conditions conducive for a jackknife if I didn’t have any braking on the trailer at all in such a descent since the wheels of the truck were providing the resistance going down the hill via engine braking and the wheels of the trailer were just rolling freely.
Do I need to be using my integral brake controller in such a condition to apply a little bit of braking to the trailer all the way from the top of the mountain to the bottom?
  • I run cruise all the time but “I” manually control what gear I descend in. My trailer brakes are cool all the time.
  • On dry roads, it's the preferred option.
    Even on slippery roads, it's the first line of defense but keep an eye on things. If it's bad enough to be concerned, better to pull off and wait for better conditions.
  • rhagfo's avatar
    rhagfo
    Explorer III
    Jackknifing would only be an issue on slippery surfaces, then caution is advised. I have used my exhaust brake on snow covered roads in 4x4 before without issue, you just need to be aware.
  • 4x4ord's avatar
    4x4ord
    Explorer III
    If you had the cruise set it is possible that your truck’s computer may have intermittently applied the truck’s and trailer’s brakes to maintain the 55 mph. (This feature is on trucks equipped with adaptive cruise control) If you have your towing display selected when going down a steep grade a bar graph will display the level of trailer braking being applied during the brake applications.
  • Only if you want to burn them up or wear them out prematurely
