Second_Chance
Nov 27, 2016Explorer II
Looking at the specs on the Jayco, the loaded pin weight will likely come in between 3,000 and 3,200 lbs. If you haven't loaded your truck (hitch, fuel, people, stuff) and put it on the scales, you may be over the ratings on the rear axle and/or tires. Something to think about.
Residential refrigerators require a hefty battery bank to operate for any length of time on an inverter - plus generator and/or solar panels to recharge. We full-time with a 12 cu. ft. RV frig and do OK.
Last I heard, Jayco was the only manufacturer in the business with a two-year warranty.
Rob
Rob
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 25, 2026
