dpgllg wrote:
Looking at the options that can be added I have two questions:
1. Is the MOR/Ryde "RPB" Rubber Pin Box at $637.00 a good investment? I understand that it helps eliminate front to back chucking. I am just not familiar with it at all. Can it be added at a later date relatively easy?
2. Will The Dual Pane Frameless Tinted Safety Glass Windows at $1492.00 significantly keep the unit cooler or warmer? I do not anticipate doing much cold weather camping. If it is cold out I want to be where it is warm!
Thanks to everyone for all there help
Dave
The MorRyde pin box would be an option I'd get, though it's not hard to add later on. Just have to have the tools to get it done, and some help to lift it into place.
From everything I've read about dual pane windows, for all but extreme conditions, I'm not sure they're worth it. Too many stories about them fogging up after a few years, then having to spend more than you paid for them to "fix" them. The biggest upside seems to be rigs with them tend to be much more quiet inside.
Lyle
