RobertRyan
Dec 21, 2013Explorer
Francesco Knowles wrote:
I think that's a mistake on Robert's part- specs for the Iveco pictured earlier indicate payload is 1000 kg- around 2200 lbs.
No the payload for the 55c is 2030kg optional to 2700kg, that works out to a weight in pounds of the lightest version of 4,400lbs or slightly over 6,000lbs for heaviest variant of the 55C. Why 55C it is under a Truck cut off 10,000GVWR
IVECO DAILY 55 C Van/5th Wheeler Light Tow vehicle.
Explore the open road in safety and comfort with the ultimate vehicle for your 5th wheeler .
Having the right vehicle to transport your home securely and safely is our goal. At Melbourne Truck Centre we have thoroughly researched and targeted to build the best 5th wheel vehicles on the market, and are positioning ourselves as the largest builder of 5th Wheel Vehicles in Australia.
Companies such as Jayco and Trulux have researched the market for the most ideal vehicle to tow their product, and have concluded that the IVECO Daily 5th Wheeler is the best tow vehicle for this task.The IVECO Daily is the ideal tow vehicle, as it is the only vehicle with full compliance for towing a 3900kg(8,600lb) 5th wheel trailer on a car license across Australia* (*HC License required in ACT).
With two models, three engine variants, different diff ratio’s and suspensions packages, you can walk away with the best customised towing vehicle for your home on wheels.
IVECO Daily Dual Cab model
IVECO Daily 50C21/DP - 4495kg(9,900lb) GVM
150kw / 205hp, 470Nm from 1250 – 3000rpm
6 speed manual transmission, 5.111 diff ratio
Optional automated transmission (125kw / 170 hp)
Features of the IVECO Daily
40 Channel UHF radio, LED rear work light
Electric brake controller, second battery, and charge cable to trailer batteries
Multimedia radio with 6” touch screen, reverse camera, GPS, Ipod, internet and blue tooth (images below)
Reverse camera will assist when connecting trailer plus
The fuel economy figures and service intervals are industry leading, providing the lowest running costs
Heated and suspended seats
Adjustable airbag rear suspension will assist in connecting – disconnecting trailer
Mirror spacer, wheel trims, side steps
2x Toolbox under tray, 15L water tank and soap dispenser
Provides a 1000 kg(2,200lb) payload when towing on a fully loaded 5th wheeler
Easy to drive, safe reassuring, roomy interior, and creature comforts
Optional extras available include bull bar with LED light bar, drop sides on tray, a
About Fifth Wheel Group
