DazedNConfused
Jul 17, 2013Explorer
Grady23 wrote:
I just installed the front 4arms on my Cougar. HINT: IF you don't already have them -- BUY a set of HIGH QUALITY drill bits and a tap/die set. You will need the 3/8 - 16 tap to do the holes in the frame. The "Self-tapping screws that are provided do not have enough taper to start and cut well. They work fine AFTER you have cut the new threads. I have a drill bit set from Dewalt, with the "bullet tip" and they worked great. Be sure to use oil on the tap and remember to turn in for one full turn and then back up about a half-turn as you cut the thread. I've found out by talking with Sonny that I need to buy an additional 2"x3"x6' piece of angle iron and bolt or weld it to the support for the rear carrier that my unit has. I haven't had time or weather to add the bracket and rear arms as of yet and only have manual sissor jacks to deal with anyway.
Thanks for the tips. Is the angle iron needed for the rear because you have scissor jacks and need a place to mount the inner points of the rear stabilizer bars?
EDIT: Sorry....didn't see the last part of your note about having scissor jacks. I won't need the angle iron...but I may need that added accessor I mentioned in my initial note. You didn't find those brackets included in the box, did you?
About Fifth Wheel Group
