JRS___B
Jul 17, 2013Explorer
If you have scissor jacks, you do not need the accessory bracket.
If you do not have scissor jacks, you will have to buy the accessory bracket.
If you have a cross-member handy/visible to attach the rear JT to, then you do not need the angle iron.
If there is no nearby cross-member to attach to, then you have to fabricate one of your own. An angle bracket, U-channel, box channel, or 1/4 inch flat stock will all work.
About Fifth Wheel Group
