lakeside013104
Jun 12, 2014Explorer
jerb wrote:
on a side note after you get camper level and lock the arms, raise or lower landing gear just a bit to take play out of everything!
Per the instructions that came with my JTs:
1. Level RV side to side and front to rear.
2. Lower the FRONT of RV 3/4" to 1" lower than the REAR.
3. Lower and set rear stabilizer jacks.
4. Tighten the "T" handle bolts on the 2 REAR Strong-Arm Jack Stabilizers.
5. Raise the FRONT of the RV to make it level: front to rear.
6. Tighten the "T" handle bolts on the 4 FRONT Strong-Arm Jack Stabilizers.
7. "BUMP" the FRONT electric jack switch so the jacks lift the front of the RV very slightly. This action eliminates the play (movement) at the bolts and bolt holes between the JT stabilizers and the RV frame.
8. Enjoy your Rock - Steady RV.
Lakeside
About Fifth Wheel Group
