- xPIXxExplorerI think I am going to make a set of the steady fast stabilizers, they are a pretty simple design. The only thing is I won't make the feet they use, I'll just bolt mine to the landing gear legs with heim joints. I figured up the materials and can do it for under $100 that's even with the nice turn handles they use to lock everything down.
- JesLookinExplorerI installed my Steadyfasts this morning. Took about 2 1/2 hours. Now that I did it once, I could do it again in an hour. There are a lot of pieces and parts, but once I figured it out it was easy.
I only did the fronts. Will do the rears if needed.
A quick preliminary test shows that the Steadyfast will work as expected. - nremtp143ExplorerEither one will do what you want it to do. Just in a little different setup. I have WinfieldRV stabilizers on mine and in conjunction with the BalChocks, I have a motion free camper. It is a personal choice just like your choice in trucks and rvs..
- huntramExplorerBill Gehr who writes reviews in trailer life tried them both and preferred the Steadyfast. From his recommendation that is what I bought. It is what he personally uses now on his 5th wheel. Truthfully they are both fine, but with the Steadyfast you only have to tighen 3 LARGE easy to reach wing nuts! All being equal that is reason enough to go with Steadyfast.
Brian - xPIXxExplorer
overthehillbill wrote:
xPIXx wrote:
5 reply's and still no answer. I am wanting answers from people who have used both, and can compare the two.
I had JT's on my first 5er and I have SteadyFast on my current one. I believe the results are about the same. The SteadyFast were a easier install and easier to use. SteadyFast customer service is great. Just my .02.
This is the type of info I'm looking for. Thank You - gmcsmokeExplorerThey are the exact same thing. One uses six locking mechanisms the other uses three.
- overthehillbillExplorer
I had JT's on my first 5er and I have SteadyFast on my current one. I believe the results are about the same. The SteadyFast were a easier install and easier to use. SteadyFast customer service is great. Just my .02. - xPIXxExplorer5 reply's and still no answer. I am wanting answers from people who have used both, and can compare the two.
- tvman44ExplorerJT's work great for us, we love them. :)
- fprestoExplorerJTs work great for me.
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 20, 2026
