received my JTs I always see them attached to the very bottom of the legs, I use a set of blocks so I don't have to put them all the way down. also helped with stabilization. should I eliminate th...
I just added JT's on the front. They seem to lock the fronts tight without using blocking. If I'm on a slope, I suppose that I'll need blocks, but otherwise I'm going to see how tight it all is without them.
