received my JTs I always see them attached to the very bottom of the legs, I use a set of blocks so I don't have to put them all the way down. also helped with stabilization. should I eliminate th...
When you push on the side of your cap does it rock side to side with the blocks under the front legs? I never used blocks, but it would shake the trailer, tighten down the JT's and no more shaking.
