received my JTs I always see them attached to the very bottom of the legs, I use a set of blocks so I don't have to put them all the way down. also helped with stabilization. should I eliminate th...
well I just went out to start. seems easy. first thing is the front jacks have the holes 90 degrees out. might have worked, but I dropped the jacks out, and cleaned them and then put them back. now the hardware will work as instructions. I did do a good cleaning, now will have to grease them. what is really needed
