received my JTs I always see them attached to the very bottom of the legs, I use a set of blocks so I don't have to put them all the way down. also helped with stabilization. should I eliminate th...
finally finished. all connected and took out blocks. ran the jack down, and it almost fell out. only had about 2 inches left inside. need to make adjustments my trailer is 23" high. how do I figure how much of the inside slide is supposed to be extended and how far the outside piece should be down.
