JEBar
Jun 10, 2013Explorer
rjsurfer wrote:
Why the need for pads at all?
Maybe my 25' 5th wheel is light but I NEVER have used anything under my landing gear pads (unless it's to help level)
Even my scissor jacks in the rear.
Ron W.
as noted by others in this thread, OEM landing gear footpads are easily bent when they are on anything but a solid/even surface .... footpads 5ers can sink and bend when on dirt/sand, gravel, asphalt, etc .... the same is true to a lesser degree with stabilizers .... there may well be aftermarket footpads out there that are so strong they won't bend when subjected to sufficient pressure but I've never found them .... for that reason we use some sort of additional pad under the landing gear pads
Jim
About Fifth Wheel Group
