goducks10
May 30, 2013Explorer
I don't see a problem except for the pin weight. Whats your payload rating from the trucks door sticker. Some 250's can be quite low. Especially in the upper trim levels. The 5'er's stickered weight will be higher than the brochure weight but usually not more than a few 100lbs. Just because the 5'er has a high GVW that doesn't mean you'll load that much in. Our 5'er has a GVW of 4300+/-lbs and we only load 1400lbs or so in it. Some people use the RAWR for figuring pin weights. That's up to you.
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 24, 2026
