lincster
Jul 13, 2016Explorer
It probably won't start, not after sitting that long, but you can try.
Probably easiest to replace the carb, then it will run just fine.
1 fill point is to go to your 40 gallon fuel station, which feeds the pump on the passenger side of the trailer.
The other fill point is for the 20 gallon fuel station that is dedicated to you generator.
If the gas is that old, probably best to drain both tanks and start with fresh.
Put a bunch of bleach in the fresh water tank, along with 150 gallons of water, and let it sit for at least 24 hours. Run this through all of the lines and faucets. Drain and fill with fresh. Repeat 2X.
Have fun!!!!
Have fun!!!!
About Fifth Wheel Group
19,042 PostsLatest Activity: Apr 15, 2026
