Y-Guy
Aug 18, 2016Moderator
You might pull a few plugs nearby see if the wiring is running to them has come loose. In the race for speed they use the backstab connectors, I've had issues with those in my rig. I went through and changed each of them to use the side wire instead. Have you replaced the plug itself? Are the lines hot?
About Fifth Wheel Group
19,042 PostsLatest Activity: Apr 15, 2026
