jamespjackson95
Aug 18, 2016Explorer
Y-Guy wrote:
You might pull a few plugs nearby see if the wiring is running to them has come loose. In the race for speed they use the backstab connectors, I've had issues with those in my rig. I went through and changed each of them to use the side wire instead. Have you replaced the plug itself? Are the lines hot?
today i will pull the plug and check behind it for power with a volt meter. the lines do not get hot. this gfi outlet controls my fridge, outside outlet, and most the inside ones... i assume i can pick up any gfi outlet at lowes to replace it?
About Fifth Wheel Group
19,042 PostsLatest Activity: Apr 15, 2026
