Bumpyroad
Sep 01, 2013Explorer
greende wrote:Bumpyroad wrote:
I would prefer one yamaha EF2400iS at 75 lbs. myself. less money, less weight, less maintenance, assuming that 2400 will work. I am guessing that if needed, a smaller one could be paired with that?
bumpy
Bumpy,
No way to pair a smaller genny unless you are running separate circuits with the two generators. The 2400 is supposed to run "most" new efficient ACs but the OP has an older carriage and I doubt his will run on the 2400.
thanks, since the OP is evidently just going to leave this in the TV bed, I would just get a 4,000 to start with and be done with it. as a full timer get it right the first time?
bumpy
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
