goducks10
Apr 01, 2015Explorer
You won't be able to tighten them down to the frame because the lower skirting on the trailer is to flimsy. When you hook the strap to the frame it has to go under the skirting then up the sidewall. You'll crush the skirting when you tighten the strap.
No for the height issue. Unless you're under the height of the AC then you may have trouble.
About Fifth Wheel Group
