TCBaxterExplorerApr 18, 2015Keeping water hotMy Atwood water heater will heat the water but not hot as expected and then will not maintain the warmer temp.What should I be looking for to correct?
enblethenNomadApr 18, 2015Check to insure that both the ECO and thermostat are tight against the tank.If yes, one of them could be failing. May want to pick up a set.
Related ContentNo flow from hot water tank Nautilus P1 systemHot water heater question .....Hot water problemHot Water ReplacementHot water element
