TCBaxter
Apr 18, 2015Explorer
Keeping water hot
My Atwood water heater will heat the water but not hot as expected and then will not maintain the warmer temp.What should I be looking for to correct?
Old-Biscuit wrote:jnharley wrote:
Our water heater does not produce great hot water either for me. I rarely turn on any cold water when showering. My spouse thinks I am crazy as he thinks the water is way too hot. Guess it is just individual tolerance levels.
NuWa still using Atwood then yours will have only one set of t-stats....under foam cover in outside compartment. 140*F/180*F
Unless it is an XT model...that one uses a mixing valve on backside of WH tank.....normal t-stat set for 160*F then cold water is mixed inside mixing valve for an output of 130*F.
Mixing valves have a tendency to clog and output temps can be luke warm
