Hvyhauler
Sep 11, 2014Explorer
mykahts wrote:Hvyhauler wrote:
The dislikes were the cheap oem st tires which all failed within 2 years.The poor workmanship 12 volt wiring system behind the power panel, I repaired all the wiring myself.The construction debris left behind panels and sealed off areas from assembly.
Hi Hvyhauler... What would be a normal lifespan for tires? Do they last longer if unit is parked more than towed along? I think I'll be ok with the wiring system as my man is good with electrical stuff. I'll have him check my 12 volt wiring out. :)
Hello Mykahts, Please share with the group the make/model of your new 5ver & make/model of your tow vehicle.The info will help answer your tire question.
About Fifth Wheel Group
