SDM's avatar
SDM
Keyless door lock
Has anyone installed a keyless door lock on their fifthwheel. Any pros on cons? What brands are you using.
  • 1 question, when you lock the door do you have to use the code or just use the lock button?
  • DH installed the RVLock keyless after the factory installed one failed. We love it! It's much easier to use than the original and per DH was easy to install. It comes with a key fob so you can remote lock or unlock it. It does come with a key too for backup use.
    As noted above, fitting loose, ours does not. It's firm.
  • Paul D. wrote:
    We have the RV Lock Brand. Absolutely love it!!!!
    Pros: easy to install
    very convenient, no more keys
    key fob works from a distance
    tone alert for lock / unlock
    back lit at night after touching buttons
    Cons: sometimes hangs up in below freezing weather (low bat and stick lube)
    fits a little loose, could solve with shim washers but not that bad.
    The batteries last us about a year , we camp 3-4 days / week from april to oct.
    One of the best accessory purchases I made for the rv. We moved it from our tow behind to the 5er and just swapped out door latches. Check directly at the company web site as they have periodic sales and usually throw in 2 key fobs. www.rvlock.com
    This is spot on and has been our experience also. Two thumbs up!
  • Keyless touch pad or key use came on my Jayco. Its worked great for over a year on original batteries. Bauer is the brand and you set your own 4 digit code. Randu
  • We have the RV Lock Brand. Absolutely love it!!!!
  • RoyB's avatar
    RoyB
    Explorer III
    Keyless is great but be sure you have the old capability of using a key mixed into the sytem to gain entrance just in case... WIRELESS FANCY stuff sometimes doesn't work. A manual key system works pretty good all the time...
    Of course all of my backup keys etc are keep in my truck and the entrance to the truck for the most part is my DOOR PUSH-BUTTON KEY ENTRY.... GO Figure hehe...
    My FRIDAY 13th comment hehe...
    Roy Ken
  • I dont have one, but one night when I couldn't sleep I was watching some RV related You tube videos and sa w one from Ray at Love your rv on installing one of these.
    He did a video and review on the unit.
    his website with a link to the video is
    www.loveyourrv.com/rvlock-keyless-entry-door-handle-install-review/
  • Ours came with it. Love it! Easy entry and easy to lock. Don't recall brand. Uses a 4 digit code.
