Ropdoc's avatar
Ropdoc
Keystone Montana 3725MK ??
Hello all,
We resently purchased the Montana 3725MK. I have 2 bikes that I need to haul. My issue is that the underside is sealed. How do I attach a bike rack? I was thinking of mounting a rack on the top of my truck, but those things aren't cheap.
Dave
  • captbru wrote:
    Had the same issue with my Keystone Laredo, sealed under body. Only way is to open it up do the bracing to the bumber and reseal. To expensive for me. Opted for the front hitch on the truck, got on curt hitch web site and found which front hitch for my truck and went to amazon and bought it alot cheaper. Very easy install and then bouught a swagman bike hitch
    Swagman XC - 2 Bike Rack Platform Style for 1-1/4" and 2" Trailer Hitchesfrom amazon.
    Have been using this set up for two years now and no problems at all, PM me if you have questions
    Same setup we have. Installed this spring and love it. Took less than thirty minutes to install the hitch. Actually took longer to assemble the bike rack. Solid as a rock and you can see your bikes.
  • Open it up, take it to a fab. shop or shop that installs hitches. then reseal it. Did this to my Cameo, pretty simple. I have carried bikes on the front of my truck, obstructs your view and catches lots of bugs and dirt. The back of that 5ver is the best place for bikes.Good luck, KB
    2011 Cameo 37RESLS
    2012 Ford F350 Lariet PSD DRW
  • Had the same issue with my Keystone Laredo, sealed under body. Only way is to open it up do the bracing to the bumber and reseal. To expensive for me. Opted for the front hitch on the truck, got on curt hitch web site and found which front hitch for my truck and went to amazon and bought it alot cheaper. Very easy install and then bouught a swagman bike hitch
