C-Bears wrote:
Mile High wrote:
C-Bears wrote:
Mile High wrote:
yes the floor. The slide floors were kind of disappointing in our Montana. They were mush around the dining table
There are a lot of residences that have 3/4" OSB used in the sub-floor and/or sheeting on the roof. In any construction method I don't see the benefit of using a heavy marine grade plywood product instead of regular plywood or OSB, unless the material could be exposed to the elements.
If floors around a dining room table were "mush" then that area was no doubt water damaged. The only way that water damage can happen in most fivers is either the slide wall/roof is leaking or someone left windows open several times and kept getting their floors soaked.
NO-NO-NO don't jump to conclusions and don't treat me like an idiot from your keyboard.
They were mush form the factory, and it was an active topic on the MOC. It was bad enough that when walking to the outside edge to get to a chair, the floor would buckle and the screws holding the table pedestal down to the floor on some units would pop out.
This was 2007. I don't know what they use now or if the problem was corrected. We didn't have that issue on our 2003 Montana, nor do we on our SOB now. At the time, the general consensus from the MOC was the Keystone change to OSB when other brands maintained plywood. Too thin maybe - I don't know. I just remember the issue and it was embarrassing.
Calm down there MileHigh....I didn't say you were an idiot, I don't know you that well. My point was a new buyer should not base his opinion on one Manufacture claiming to use marine plywood and then a poster who claims to have owned a Montana at one time claims they only use OSB.
Chances are if there was an issue with "soft" floors in the slides seven years ago with some of their models they probably corrected it.
I am sure you are happy with your current purchase and I know I am happy with mine. As I said in my earlier post, not sure any make/model in the same price range is better than any other one.
We are full time and travel between 6,000 and 10,000 miles a year in our Montana fivers. We have experienced all type of weather conditions with no major issues. Does that prove to anyone that they should purchase a Montana FW, no absolutely not. It just means that we have had good luck with the ones we have had.
No - your point was you were trying to impose your own assumptions I had water issues rather than just accepting my background in the issue that is a factory change that resulted in an issue experienced by many.
