Ready to Pull the trigger and order a K&N oil filter for the 5.5 onan q.v., 2017 model. Like the 1 inch nut built on the filter. Couple of questions. Is the number HP 8029 correct for replacement o...
Does it specifically state on the box the filter comes in, not to use the nut to tighten the filter? I can certainly see someone using the nut with a torque wrench to tighten to the factory torque specs.
