ford_truck_guy
May 09, 2018Nomad
IF it is the Lippert 6 point leveling system, there is a note on the fix online..
Basically, you remove 1 QT of the hydraulic oil, and replace it with 1 QT of the names listed below - -
Solution
Lippert has an approved modification, which involves replacing a quart of the existing fluid with an anti-stiction fluid.
Refer to the Lippert technical fix, LIP Sheet – 0295
Select the link to view the Lippert Sheet - Adding anti-Stiction Fluid
Introduction
If you experience a popping noise in the Lippert (LCI) Leveling system, Lippert has approved replacing a quart of the existing oil with a quart of anti-stiction fluid. They approved the following fluids:
Caterpillar Hydraulic Oil Additive 1U-9891 (Note – many owners indicate this is the most effective option)
Torco RFF Grade 15
Maxima Fork Oil Grade 15
For maximum results, in the shortest amount of time, please follow the preparation and procedure exactly as written below. Failure to follow these steps may result in delayed resolution of the audible disturbance.
Preparation:
Obtain a clean container, with at least a one (1) quart capacity
Obtain a fluid extraction device - siphon, turkey baster, etc.
Hitch RV to the truck and fully retract all leveling jacks and hydraulic slides
Purchase one of the three replacement fluids
Fluid Exchange Procedure:
Using the fluid extraction device, remove one quart of fluid from the power unit hydraulic reservoir
Add 1/2 quart of the replacement fluid you selected
Extend all hydraulic slides and leveling jacks fully
Add the remaining amount of the replacement fluid
Fully retract all hydraulic slides and leveling jacks
Run the Auto-Level feature on the Level-Up system, as per the instructions found in the Owner's Manual.
Note: If the popping noise persists, the addition of a second quart may be necessary. Repeat the steps under Fluid Exchange Procedure, in the same order.
Solution
Introduction
Torco RFF Grade 15
Preparation:
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
