minnow wrote:
How much of a job was it replacing the motor. I've seen the videos and looks to me like little to no room to access the motors.
There is enough room to get one arm / hand in, which is all you need. As with hitching, and un hitching you may have to manually move the slide to take the pressure off the motor, but it pops up and back. It then just pulls out. One thing I learned while doing the job is to index the drive so it goes back in the same position as it came out. There are two pockets for the outside set screw. Square that with the wall to get position of the drive gear. It also helps if the slide is about half way, that makes reaching the motor easier but it still can be done all the way in.
