remdog_1
Sep 28, 2016Explorer
Thanks for the help and suggestions. I did put jackstands under frame just in case, but did not need them.
I did have to use the manual turning rod to align with the spline on the motor shaft. All in all it was easy switch.
I don't understand why the factory used a plastic case instead of the aluminum one I replaced it with, I guess it has to do with cost.
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 22, 2026
