12thgenusa
Dec 24, 2015Explorer
Do you still get the noises when the weight of the trailer is still on the truck?
As far as I know, there is no requirement to lube anything on the landing gear.
This is not directly related to your problem but something you might want to correct. The wires looped over the drive shaft below the drive motor are a bad idea as the shaft rotates whenever the motor is running. I would try to reroute them.
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 31, 2026
