cummins2014 wrote:
fj12ryder wrote:
One of the main advantages of two separate motors is two separate controls so you can control the motors independently. They will run at the same speed so that part doesn't matter.
Yes ,but we are missing the point here or are we :), if one is binding a bit ,then no they won't run the same speed, and will have to be adjusted independently , thats the nice thing, but then again you still have to watch ,and make sure you are not coming up crooked ,and putting more bind on the legs.
Keeping them lubed up, and not over extending them to the end, and messing up the worm gear, then regardless one or two motors, they will run okay.
Mine with one motor runs fine after messing up some gears, and having to replace one, then knowing what to do.
Actually the OP didn't say anything about his motor binding up, he just commented that it runs really slow and labors. And they do run very slow even when new. My Fuzion ran so slow that you basically had to chalk the legs to see if they were moving. But I do agree that keeping them lubed is a very good idea.
"I've =seen= factory installed 2-motor/2-switch legs in operation and they =always= had to adjust one side as that motor just ran faster when both switches were pressed at the same time. (FWIW, old GF's father's FW.) The 4-pt system on my KZ, on a virtually level concrete pad always runs one more than the other. You simply can't sync the motors that closely without complex and expensive electronics involved.
Other thing about having 2 motors is that the legs jack about 2x faster, if not more, than a single motor setup. Old Komfort had the single motor and it was =slow=!"
A fair amount of misinformation here, I have the Bulldog unit with two motors, and two switches. The motors run the same speed, no fancy electronics that I can tell. But they go up and down with no adjustment needed unless the ground is unlevel.
As for double motors running 2X as fast as a single motor, that's not necessarily true. They may run a lot faster, but they also may only run a little faster. The Bulldog system has two settings: High Speed, and High Torque. One is pretty fast, and the other isn't a whole lot faster, but still some faster.
