Swamp_Man
Jun 26, 2013Explorer
If the switch is working, then I was check the motor next. I had a slide out motor then went bad but did not blow the fuse. Just up and died. Replaced it and everything worked again. But may sure you eliminate all of the other causes before purchasing a motor. You might even have a contact that has burnt inside the fuse holder.
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
