Charley67ExplorerJun 11, 2016Landing Gear ProblemMy landing gear works (slowly) when cord is plugged into truck, but has stopped working on shore power. The 30 amp bus fuse near switch appears not to be blown. Any ideas?
GACamperExplorerJun 12, 2016If your able to disconnect the battery and put it on a slow charge. It may come back for you....Good Luck!
Related ContentLanding gear problemsLanding gear problemLanding gear/jack problemReplaced landing gears and switch. Switch extends both wayslanding gear issue
