Charley67ExplorerJun 11, 2016Landing Gear ProblemMy landing gear works (slowly) when cord is plugged into truck, but has stopped working on shore power. The 30 amp bus fuse near switch appears not to be blown. Any ideas?
GACamperExplorerJun 14, 2016If you have a electrical tested trace the wires and see where the power stops. You could have a bad wire or bad or loose connection.
Related ContentLanding gear problemsLanding gear problemLanding gear/jack problemReplaced landing gears and switch. Switch extends both wayslanding gear issue
