My landing gear works (slowly) when cord is plugged into truck, but has stopped working on shore power. The 30 amp bus fuse near switch appears not to be blown. Any ideas?
Every one is right when they say the landing gear runs off your battery. I would check you inverter (shore power charger). Could be it's not working and allowing your battery to drain. If it is working properly you should have plenty of juice to operate the landing gear, even with a weak battery.
