0rion's avatar
0rion
landing gear question....
Last year I didn't run into this a single time and this year I've had it happen a few times and it's kinda got me puzzled.
A few times now when running the legs up or down if I have to go very far the motor just stops. If I let off the button and press it again it'll work fine for a while and then shut off again. I have a couple guess' as to what's going on but if someone knows exactly what it is I'm all ears. I'm guessing it's either a thermal protection feature for the motor because it seems to only happen if I'm running the gear for a longer time than usual. My other guess is perhaps a battery draw issue since I *think* it's only happened when on 12v. It's done it both going up and down. The last couple of times it's done it I'll give it 30 seconds or so to cool down in case it is a thermal protection deal. I'm just curious as to why it didn't do it last year.
One thing I noticed this last time that I'd never looked at before is the motor when the gears are running....the motor is moving around quite a bit. Is it supposed to do that or be rock solid?
