bpounds
Jun 09, 2016Nomad
Usually in the front compartment, you will find the motor on one side, and a long square tube running over to the other side. The pins are in each end of that square tube. Often they are just a bolt and nut, which can loosen and fall out. Sometimes they shear, but in my experience more often they have just loosened up.
Can also be a pin in the pinion gear.
About Fifth Wheel Group
