Having a bad hip and back is anybody build a block to put under the landing leg so a person don't have to get down to release the leg slide to pin it in place. thinking of building one10in wide by 12 ...
I've seen blocks like that RV'ers have built. The one I liked the most the RV'er had added a staple shaped piece of steel rod that stuck up from the block at a slight angle about two feet. He used this to maneuver each block into place. He hardly had to bend over.
