ret-minerExplorerJun 06, 2016Landing gearHaving a bad hip and back is anybody build a block to put under the landing leg so a person don't have to get down to release the leg slide to pin it in place. thinking of building one10in wide by 12 ...Show More
Old-BiscuitExplorer IIIJun 06, 2016I just use the 'handle end' (loop) on my awning rod to pull pin out...then let them snap in placeI also use the 'hook end' of awning rod to lift the inner leg back upNot a fan of high blocks under landing gear legs.....wobblyI do use a board under them to spread weight
Related ContentLanding GearFaster Landing GearLanding gear questionLanding gear failureLanding gear problem
