dryfly
Nov 05, 2018Explorer
Landing gear/jack problem
One landing gear on my 5th wheel has began to make a terrible noise.  Sounds as though it is binding when lowering or raising the trailer, and is coming from one of the 2 1/2" square tubes located inside the storage compartment.
I pulled the top cover from the tube and apparently the two gears are in good condition and are turning. In fact, I believe the assembly is still raising and lowering the trailer, but the binding sound is so severe I hesitate to do this because something is going to give.
I have worked on just about everything on a trailer but not these assemblies. Any idea where I might find a diagram of whats inside the square tube? From a little searching, these legs may not be re-buildable but may require replacement of the entire leg.
Any help or ideas appreciated.
