I have a 2008 montanna 5th wheel. The front landing jacks always pops a fuse. I am always replacing it with a 30 amp, I noticed that the motor is very lose when it goes up or down. Any help on what it...
Landing gear? Too weak to lift the trailers nose. Consider upgrading to dual motors. Water heater? Hearing element or hi limit switches. What brand water heater do you have? If it is a suburban, you need to check for voltage at the element. 120VAC present? Element. No 120VAC the limit switch pack. Element is available at any big box store. Limit switch pack, about 25 dollars at any good rv parts store.
