- BunklashExplorer
Nutinelse2do wrote:
Are you all using DRY dryer sheets or WET ones?
Wet ones. And I too vote against the spray and wipe cleaners. Just use regular car wash soap.
If it gets to the point where it won't take a shine, check this out:
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/25818736/srt/pa/pging/1/page/1.cfm
Many thanks to 4X4van. I used his technique a few weeks ago, I'll report on how it holds up.
Love this forum! - Nutinelse2doExplorerAre you all using DRY dryer sheets or WET ones?
- I spray the front of my class C with water (or do this cleanup on a damp foggy morning), then did a long-handled mop into bug-removing windshield washer fluid, give the bugs a quick rub with that, and quickly wash it off with water. So far no problems and no climbing up to reach it with the dryer sheets.
- RVUSAExplorerI just spray the front with pam and then hose it off when I get where I'm going.
- BillinPSLExplorerI would recommend against Simple Green, it will strip any wax/sealant you apply plus it is very corrosive.
- EycomExplorerIt's the only way I've gotten through the biannual lovebug seasons all these years in Florida.
- Desert_CaptainExplorer IIIThe simple green will go through your wax in no time but the used dryer sheets remains one of the best tips I ever got here. After 4,100 miles the front of our Class C, perhaps the ultimate bug catcher, was bad but three dryer sheets later looking good. :C
- T-10_ParabolicExplorerI use Bar Keepers Friend to remove bugs.. Workz great...T-10
- RanduExplorerI spray a little Simple Green on the area and then wipe down with the dryer sheet. Has just a bit more kick that way. Works real well if good coat of wax is kept on nose. When the bugs start getting real tough even with the dryer sheet, I know I have to wax. Randu
About Fifth Wheel Group
19,007 PostsLatest Activity: Feb 28, 2025
