joelc
Jul 21, 2013Nomad
I do not understand how water comes through the glass unless you are talking about condensation. Remember if you do have a leak water does travel and follows the path of least resistance. Check the sealant around the window. It is possible that if you really have a window leak you should either reseal around the window or you might have to do the major operation of removing the window and reseal the entire area between the window frame and the RV.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
