Travlingman
Jan 28, 2019Explorer II
If you are not at the point of wanting to change out to a braided line, here is something to try before pulling fridge. With the water on, check the line from fridge to it's outside exit of the slide. Usually ran behind the cabinets, might have to pull a drawer or 2 out. You will probably find a little pin leak. Pick one of these up at Lowes. Cut line and splice in. And once these lines start leaking, they will continue in other spots.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
