mdryden
Mar 22, 2020Explorer
Leaking antenna fix
Hi.  Got a new to me 2007 next level made by holiday rambler.  While inspecting roof I noticed that the coax cord to the antenna was in bad shape.  I decided to replace it which involved removing the antenna for access to the connection.  The trailer spent a majority of its life in s California.  I m glad I removed it (sort of). I noticed that water had been leaking down past the boot for the coax.  The luan was wet in the area under the antenna but not soft.  No damage or moisture to the insulation or ceiling.  I left it open for a day (rain was coming) and reinstalled the antenna.  I used butyl for the base and finished it up with self leveling caulk.  I have been running a dehumidifier and forcing hot air into the ceiling with a hair dryer.  Everything seems ok but I worry about mold and how much of the luan got wet.  Does everyone think that I repaired it correctly or should I pull it back off and peel the membrane back?  The membrane wasn’t glued to the luan directly under the antenna, so the luan was wet as far as I could see.
