r1Mk's avatar
r1Mk
LED light mod
I pulled the stock fog lights off my 06 Sierra, replacing them with some LED pods and added a 22" curved light bar. So far, I'm pretty happy with the out come. I also found a way to run your high beams, low beams, and fog light all at the same time Clicky
The pods were from sidetrackedoffroad.com and the light bar is a curved 22" light bar from Mictuning off of Amazon.
Here is schematic for the fog/high/low beam mod
I also found a nice set of plug and play replacement headlights from Putco (which are not pictured)
Clicky
  • Looks good. I've thought about doing that with my Dodge but it will block some of the cooling.
  • It does get dark in country out here, but not as dark as the dunes.
  • sch911 wrote:
    I'm sure these massive lighting upgrades are for off road use only right?
    the OP lives in Modesto. Ever been to Modesto? It's not exactly a well lit town once out of towntown area. The Central Valley is DARK
  • I'm sure these massive lighting upgrades are for off road use only right?
  • That's the awesomeness of the Sierras is the ability to mount a light bar without blocking airflow to the trans cooler, and that there's round LED lights to mount in place of the factory fogs.
