Miles_Away
Mar 27, 2016Explorer
The tail/brake lights on my fiver are mounted inside the body cavity and are not separate fixtures that can simply be replaced. I went to SUPER BRIGHT LED's (superbrightleds.com)and purchased a square wafer LED which is attached to a wire with an 1157 plug that plugs into the trailer. Because of its size they have over twice the number of LED and are super bright. Be sure to purchase the red LED lights if you are using them with a red lens, white only if using with a clear lens. They are much brighter than the OEM bulbs and have the instant on feature.
About Fifth Wheel Group
19,042 PostsLatest Activity: Jun 03, 2022
